Move last word to first word in field calculator
525
12
10-21-2021 08:50 AM
KatharynHanki
Hi!
I'm trying to give watercourse names their French name from their English name, so I need to change the order of words a bit such as:
Wind Ruisseau -> Ruisseau Wind
I can remove Ruisseau with !Nom![:-9], but I can't figure out how to place it in the front with a space.
Some watercourse names hare three words like
West Wind Ruisseau
Would using an UpdateCursor be more simple than trying to figure out an expression in the Field Calculator?
Thanks!
JoshuaBixby
>>> s = "Wind Ruisseau"
>>> " ".join(s.split()[::-1])
'Ruisseau Wind'
ABishop
"West Wind"+' ' +"Ruisseau"
Amanda Bishop, GISP
KatharynHanki
I need to do it for thousands of unique names that end with "Ruisseau" and make them start with "Ruisseau"
ABishop
Are the unique names in a specific field you can call out?  In this case, you could use the field calculator  to do this:
"Ruisseau"+' ' +[FIELD NAME]
Amanda Bishop, GISP
KatharynHanki
Ah yes, that's a much more simple solution than I was thinking. I think this should work, thank you!
JoshuaBixby
>>> s = "Wind Ruisseau"
'Ruisseau Wind'
KatharynHanki
Thanks! I'll give this a try as well.
Can I make my field equal s?  like  s = !Nom! so it selects my selected rows from this field?
KatharynHanki
Just tried with field name, which absolutely works! Thanks kindly.
KatharynHanki
Hi Joshua,
Is there a way to I could keep the order of the middle words when there are three words in the string?
For example, this expression also reverses the names of the other words:
'West Wind Ruisseau' becomes 'Ruisseau Wind West'
and I would like 'Ruisseau West Wind'
BlakeTerhune
MVP Regular Contributor
Here's another solution to consider.
s = "West Wind Ruisseau"
s = s.rsplit(" ", 1)
last_word = s.pop()
s = " ".join([last_word] + s)
