loop through MXDs for change of name and type (Shp to GDB) in one layer only
151
06-12-2024 12:30 PM
kaww02
I thought I had this working before with your help but I was mistaken. I have continued to tweak and here is where I am. When I run it in VB I get the error:  "EOL while scanning string literal"
In all the forums and documents I see I can't seem to find a shapefile to a completely new location/GBD. I wonder if I need to break this change up so that maybe I change name  (to new GBD file name) then change source - IDK. Here is the code:
import arcpy
from arcpy import env
# Set the workspace for the folder containing MXDs
arcpy.env.workspace = r"C:\Test2"
mxdList = arcpy.ListFiles("*.mxd")
# Iterate through all MXDs in the workspace
for mxd in mxdList:
    mxdpath = env.workspace + "\\" + mxd
    print (mxd + "Is being processed")
    mxdNext = arcpy.mapping.MapDocument(mxdpath)
    for lyr in arcpy.mapping.ListLayers(mxdNext, "old_shapefile", df):
        if lyr.supports("DATASOURCE"):
            if lyr.dataSource == r"C:\Test\Old_Shapefile.shp":
              lyr.replaceDataSource(r"C:\Test\Old_Shapefile.shp", "SHAPEFILE_WORKSPACE",
              r"C:\Production_Data\Test\Final Data.gbd","FILEGDB_WORKSPACE", "New_Name")
             lyr.name == "New_Name":
        print("lyr.name")
    mxdNext.save()
    arcpy.RefreshTOC()
    del mxd
AlfredBaldenweck
MVP Regular Contributor
On line 23, you have
If you change it to
r"C:\Production_Data\Test\Final Data.gdb"
 does that fix the issue?
If not, please also let us know the line that the error is occurring on.
Also, actually more to the point:
Add an "if" to the beginning of line 24 and indent line 25 twice.
kaww02
Thank you @AlfredBaldenweck  I made those changes but still the same error.
The error seems to reference line 21
TonyAlmeida
Your indentation looks off, and I added iteration over data frames.
# Assuming a DataFrame is defined or selected in the map document
    for df in arcpy.mapping.ListDataFrames(mxdNext):
                    lyr.replaceDataSource(r"C:\Production_Data\Test\Final Data.gbd", "FILEGDB_WORKSPACE", "New_Name")
                    lyr.name = "New_Name"
                    print(lyr.name)
