Hello and Happy New Year!
I am writing a Python script that ingests a layer from a branch-versioned feature service, changes the version, and then updates the data. I've not found any way to verify that arcpy.ChangeVersion_management() actually changed the version, other than assuming that no exception being thrown means it was successful.
There is no workspace property on the feature layer's Describe object, and no other properties other than canVersion and isVersioned. Has anyone else encountered this and found a way to check the active version? Thanks
- Jack C
Try using a layer's connection properties?
aprx = arcpy.mp.ArcGISProject("CURRENT")
mp = aprx.activeMap
lay = mp.listLayers()[0]
print(lay.connectionProperties["connection_info"]["version"])
#dbo.DEFAULT
Try checking it before and after running your changer.
Caveat here is I've never worked with branch-versioned stuff, but this is how it works for traditional versioning.
mp = aprx.activeMap
#dbo.DEFAULT
Hey Alfred,
Thanks for the response! Implementing an ArcGISProject into the script was my next attempt and I should have tried that before posting because indeed I can get the version of a layer in the ToC.
Here is a function I use
def get_workspace(desc, version) -> tuple[str, str]:
if getattr(desc, "dataType", None) == "ShapeFile":
return desc.path, "folder"
if desc.path.casefold().startswith("http"):
if not version or version.casefold() == "sde.default":
return desc.path, "service"
else:
return f"{desc.path};version={version}", "service"
else:
return get_workspace_desc(desc).catalogPath, "gdb"
def active_edits(self, layer):
# Dont ask me how this works, I forget
if not layer or not layer.connectionProperties:
return True
else:
return False
def change_version(self, layer_name):
# Note, this does not appear to work with a layer object, use the layer name
if self.workspace_version is None or self.workspace_version.casefold() == "sde.default":
return None
if not self.is_service:
return None
# Not sure if the normalization is needed
logger.debug(self.workspace)
pth = get_workspace(arcpy.Describe(layer_name), None)[0]
logger.debug(pth)
if os.path.normpath(self.workspace) != os.path.normpath(pth):
return None
logger.debug(f"Changing {getattr(layer_name, 'name', layer_name)} to {self.workspace_version}")
result = arcpy.ChangeVersion_management(layer_name, "BRANCH", self.workspace_version, None, "EXCLUDE")[0]
logger.debug(result)
if self.active_edits(result):
logger.error("Cannot preform Calculation with Active Edit Session")
raise SystemExit(1)
try:
logger.debug(result.connectionProperties)
if result.connectionProperties["connection_info"]["version"] != self.workspace_version:
logger.error("Version was not changed, exiting")
raise SystemExit(1)
except Exception as e:
logger.error(f"Unable to change version. {e}")
raise SystemExit(1)
return result
Hey Mike,
This is a great code reference for future use, thank you!
