I have a python (ArcGIS Pro 3.3.2) script that created a raster file then published it to ArcGIS Online as a Tile Layer item using this series of instructions
sharing_draft = map_.getWebLayerSharingDraft("HOSTING_SERVER", "TILE", rest_id)
sharing_draft.serviceName = rest_id
sharing_draft.summary = snippet
sharing_draft.tags = tags
sharing_draft.description = description
sharing_draft.portalFolder = None
sharing_draft.overwriteExistingService = True
sharing_draft.credits = attribution
# Create Service Definition Draft file
sddraft_output_filename = os.path.join(arcpy.env.scratchFolder, rest_id + ".sddraft")
sharing_draft.exportToSDDraft(sddraft_output_filename)
sd_output_filename = os.path.join(arcpy.env.scratchFolder, rest_id + ".sd")
arcpy.StageService_server(sddraft_output_filename, sd_output_filename)
rsp = arcpy.UploadServiceDefinition_server(sd_output_filename, "HOSTING_SERVER")
That works great but now I want have an updated raster and I want to overwrite the data original ArcGIS Online Tile Layer item. I thought that since I'm setting "overwriteExistingService" that it would work as is, but instead I get this error on the UploadServiceDefinition call:
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Service name 'Access_to_Nature_Raster' already exists for 'dJOijx2lWTlGQBDJ'
Failed to execute (UploadServiceDefinition).
I looked inside the sddraft file to verify the the Type setting is 'esriServiceDefinitionType_Replacement'. What is the trick to making this work?
So I have had a lot of trouble overwriting web feature layers, since it is just the generic 999999 error try adding something like aprx.save() if you are publishing from an arcgis pro project. Ensure that the source layer id's are the same and map layer id are the same. Even with unique layer id's checked; if those were not the same I would get issues publishing.
The rest of your code looks exactly like mine, so must be gremlins
