Field Calculate syntax error
975
10
01-14-2022 11:04 AM
2Quiker
Occasional Contributor II
Trying to figure out a simple field calculate but I can't i keep getting syntax error. This is a shapefile.
I need to update the updateField field. The updateField is a text field.
def Reclass(SC):
    if (SC == "GR"):
        return = GRAIN
    if (SC == "WR"):
        return = WRITE
    if (SC == "PL"):
        return = PLACE
updateField = Reclass(!SC!)
AdrianWelsh
MVP Honored Contributor
If you're trying to return text, do you need quotes around your text returns?
2Quiker
I have tried it with quotes and still get the syntax error.
def Reclass(SC):
    if (SC == "GR"):
        return "GRAIN"
    if (SC == "WR"):
        return "WRITE"
    if (SC == "PL"):
        return "PLACE"
by Anonymous User
Not applicable
Hello 2Quiker,
Does the syntax error identify a certain line of code?
I wonder if your return statements need to also be in quotations to be returned as text. "GRAIN" instead of GRAIN.
Cheers,
Mike
2Quiker
Total rookie mistake, I forgot to check the python parser box.
AdrianWelsh
Oh no! Was it in vbscript or Arcade? At least you got it figured out!
2Quiker
It was in vbscript, so I though I had it figured out but I guess not. The following only works with one if but when adding more elif I get an error that field is not nullable. How do I handle Nulls and blanks in field calculator? The SC field dose have some nulls and blanks.
def Reclass(SC):
    if (SC == "GR"):
        return "GRAIN"
    elif (SC == "WR"):
        return "WRITE"
    elif (SC == "PL"):
        return "PLACE"
AdrianWelsh
What do you want to do with nulls? Leave them null? The python syntax for null is "None".
So you could write something like:
if SC is not None:
    If (SC == "GR"):
        return "GRAIN"
    elif .... and so on
2Quiker
Using what you posted if SC is not None: but still have me the error "The field is not nullable". So I check the attributes filed and there are some blanks and nulls. I am trying to run this on the how feature class table not just the selected features.
def Reclass(SC):
 if SC not in [None, "", " "]:
    if (SC == "GR"):
        return "GRAIN"
    elif (SC == "WR"):
        return "WRITE"
    elif (SC == "PL"):
        return "PLACE"
DanPatterson
MVP Esteemed Contributor
def Reclass(SC):
        if (SC == "GR"):
            return "GRAIN"
        elif (SC == "WR"):
            return "WRITE"
        elif (SC == "PL"):
            return "PLACE"
    else:
        return "grief a null"
you need to tell it what to do if there is one of those no-no cases
... sort of retired...
