Extend line (not within) up to polygon feature?
86
2 weeks ago
JohannesBierer
Hello,
I've found a script of JoshuaBixby from here:
https://community.esri.com/t5/python-questions/extend-line-up-to-polygon-feature/td-p/705806/page/2
it work well to extend lines within a polygon up to the border of the polygon feature. But it couldn't work with lines which are somehow between the polygons (see attached image - in black original line).
Could you think of a solution for this?
I tested "Have their center in" in line 21 instead of "within" but it doesn't work ...
I use notebook in ArcGIS Pro 2.9
# -*- coding: utf-8 -*-
import arcpy
import math
arcpy.env.workspace = FGDB
arcpy.env.overwriteOutput = True
dist = 100
fc_line = "line feature class"
fc_line_1 = "Sperren_C_1"
arcpy.CopyFeatures_management(fc_line, fc_line_1)
fc_line_FL = arcpy.MakeFeatureLayer_management(fc_line_1, "fc_line")
fc_poly = "Polygon Feature Class"
fc_poly_FL = arcpy.MakeFeatureLayer_management(fc_poly, "fc_poly")
with arcpy.da.SearchCursor(fc_poly_FL, "SHAPE@") as scur:
    for poly, in scur:
        boundary = poly.boundary()
        arcpy.SelectLayerByLocation_management(fc_line_FL, "WITHIN", poly)
        with arcpy.da.UpdateCursor(fc_line_FL, "SHAPE@") as ucur:
            for line, in ucur:
                arr, = line.getPart()
                SR = line.spatialReference
                p1, p2 = arr[0], arr[1]
                angle = math.atan2(p2.Y - p1.Y, p2.X - p1.X)
                p = arcpy.Point(p1.X - dist * math.cos(angle),
                                p1.Y - dist * math.sin(angle))
                arr.insert(0, p)
                pn1, pn = arr[len(arr)-2], arr[len(arr)-1]
                angle = math.atan2(pn.Y - pn1.Y, pn.X - pn1.X)
                p = arcpy.Point(pn.X + dist * math.cos(angle),
                                pn.Y + dist * math.sin(angle))
                arr.append(p)
                line = arcpy.Polyline(arr, SR, True, False)
                line = line.cut(boundary)[1]
                p1, pn = arr[0], arr[len(arr)-1]
                p1.Z, pn.Z = 0, 0
                arr.insert(0, p1)
                arr.append(pn)
                ucur.updateRow([line])
JeffK
by MVP Regular Contributor
Maybe you can store the length of the line (either original line length or after the extension) and then check it after it is cut by the boundary to see if there is a difference and go from there?
JeffK
JohannesBierer
Thank you, I will try it.
