Creating multipart polyline with Z values
767
08-14-2022 07:29 AM
kradijaf
New Contributor III
Trying to create multipart polyline from array of arrays (arcpy.Polyline containing multiple arcpy.Array (each is a singlepart line)) or list of coords. Tried it in multiple ways.
Inserting a list of 3D coords into Z-enabled feature class as shown in https://pro.arcgis.com/en/pro-app/latest/arcpy/get-started/writing-geometries.htm class only worked for singlepart features for me.
Creating multipart polyline without Z values also works as also shown in Write Geometries:
This also didn´t work after I added z-coord into the points.
Created multipart polyline without z-coord, inserted it into Z-enabled feature class. Tried to update z-coords using script similar to https://community.esri.com/t5/python-questions/change-z-coordinates-of-vertexes-by-updatecursor/m-p/... but applied to ArcGIS Pro 2.9, the script can run without errors. After I change z-coord of a point, .Z property prints correct z-coord. But after I create a new multipart polyline from points with correct Z-coord and update the row with it, Z-coords of all updated polyline points are equal to 0.
Does anyone know how to solve this?
JohannesLindner
MVP Frequent Contributor
Code screenshots are hard to work with, because we can't easily test what you did. To post code as text:
Passing a simple list of coordinate tuples to the InsertCursor seems to be a shortcut that is only valid for singlepart features. Personally, I always create an arcpy.Geometry object and pass that.
test_fc = arcpy.management.CreateFeatureclass("memory", "test_fc", "POLYLINE", has_z="YES", spatial_reference=4326)
coordinates = [
    [-117.2000424, 34.055514, 1],
    [-117.2000788, 34.0592066, 2],
    [-117.1957315, 34.0592309, 5],
    [-117.1956951, 34.0556001, 2],
with arcpy.da.InsertCursor(test_fc, ["SHAPE@"]) as cursor:
    points = [arcpy.Point(c[0], c[1], c[2]) for c in coordinates]
    line = arcpy.Polyline(arcpy.Array(points), has_z=True, spatial_reference=4326)
    cursor.insertRow([line])
multipart_coordinates = [
    [coordinates[0], coordinates[1]],
    [coordinates[2], coordinates[3]],
    parts = arcpy.Array([
        arcpy.Array([
            arcpy.Point(p[0], p[1], p[2]) for p in part
        for part in multipart_coordinates])
    line = arcpy.Polyline(parts, has_z=True, spatial_reference=4326)
Have a great day!
Johannes
JohannesLindner
coordinates = [
        arcpy.Array([
Have a great day!
Johannes
