Creating Layers from files in memory
1026
09-20-2021 09:37 AM
mattkramer
Hello,
I was wondering if it was possible to create an "in_memory" or a "memory" feature layer from a downloaded zipped shapefile, without saving that zip file to the disk.  I am hoping to download multiple zip files from an ftp site and compile them into one final deliverable with only the final shapefile or feature class being written to disk.
BlakeTerhune
MVP Regular Contributor
Could you use tempfile.mkdtemp() to make a temporary directory to unzip the shapefile and then clean it up when finished?
BlakeTerhune
mattkramer
I was able to get this to work, I ended up using:
with TemporaryDirectory() as TempDownloadLocation:
            Download files using TempDownloadLocation
This format so once the code within the "with" statement was done, the temporary folder gets cleaned up automatically.
Thank you!
Luke_Pinner
If you're using ArcGIS Pro 2.8+ you could install geopandas (in a cloned env). You can read from a zipfile URL directly into a geodataframe, append more geodataframes, and then write out to file
import geopandas as gpd
a_url = 'https://github.com/Toblerity/Fiona/raw/master/tests/data/coutwildrnp.zip'
gdf = gpd.read_file(a_url)
another_url = 'https://github.com/Toblerity/Fiona/raw/master/tests/data/coutwildrnp.zip'
gdf.append(gpd.read_file(another_url))
gdf.to_file('test.shp')
mattkramer
Since I will be packaging this into a tool for other users to use, I decided to not go this route.  I don't think I can get some non programming folk to install geopandas.  Thank you though!
