Checking folder within a folder
384
05-13-2022 05:44 PM
MitchellMoore
Hello,
I need to check to see if there are any folders that exist ( empty or with data) within another folder. I am trying to create a custom tool that will check that.
so if there is any folder within a folder, the tool will display some message.
Any help on creating such a python script will be very helpful: ) thanks!
DanPatterson
MVP Esteemed Contributor
python's os.path, pathlib, glob and arcpy's da.Walk
all have means to traverse a folder structure and return various bits of info (eg list of folders and their files etc)
have a look and see what suits your particular needs
... sort of retired...
MitchellMoore
Hi Dan,
Thank you a lot. I know da.walk can walk top to bottom, but i think my problem is about writing the actual code. like how to do check simply if there is a file folder within a file folder ?
BlakeTerhune
MVP Regular Contributor
Using the os module:
import os
root_dir = r"C:\yourFolderNameHere"
subdir = [
    i for i in os.listdir(root_dir)
    if os.path.isdir(os.path.join(root_dir, i))
if subdir:
    # handle having subdirectories
This will create a Python list with the name of all folders that exist within your root_directory folder. If there are no folders, the result will be an empty list, which is falsy when evaluated with an if statement.
