Change Python to run script as 32bit
37810
7
02-02-2016 06:22 AM
TiffanySelvidge1
Occasional Contributor III
I have seen this asked once before but not answered.
How can python script be directed to run as 32 bit rather than 64bit? I have some vb code in my script from multiple Calculate fields. Eventually I will convert it all but right now I really need to get my script running with Windows Task Scheduler.
I have Python 2.7.8; Windows 7; Arc 10.3.1.
I can open the python command window and run 32 bit so the server has 32 installed, I just can't get my script to automatically run as 32bit.
JakeSkinner
Esri Esteemed Contributor
Hi Tiffany,
You can get a python script to run as 32-bit by following the below steps:
1.  Right-click on your script in Windows Explorer > Open With > Choose Default Program
2.  Browse to the python.exe file located under the 32-bit installation (i.e. C:\Python27\ArcGIS10.3\python.exe)
3.  Check the option 'Always use the selected program to open this kind of file'
JakeSkinner
Hi Tiffany,
TiffanySelvidge1
I have now directed and redirected it multiple times but it still insists upon opening in the 64bit.
TiffanySelvidge1
Jake,
It now opens with 32bit. I changed the name of the 32 bit python to python32. Then I (again) redirected the file to open with 32bit.
Thanks for your help!
Brownschuh
...I changed the name of the 32 bit python to python32...
What exactly did you change the name of?  python.exe?  pythonw.exe?
Right now I am struggling with this issue on a server, both 32 and 64-bit versions of python are installed.  Even if I manually try to run a script using the 32-bit version, it always runs in 64 ...
TiffanySelvidge1
Do you happen to know how to configure Python Idle to work with the 32bit? Once I changed the default program to 32bit my option to use Idle is no longer available. When I open Idle it shows itself as using 64bit.
JayantaPoddar
MVP Esteemed Contributor
The 32-bit IDLE can be found here
C:\Python27\ArcGIS10.3\Lib\idlelib\idle.bat
You could create a shortcut of the above file on Desktop.
For details, refer the following blog
64-bit vs. 32-bit Python explained | Support Services Blog
Think Location
TiffanySelvidge1
Cool. Thank you!
