Recently stumbled upon… Using conda in spyder
I will just leave this as a thought. It is one of those IPython %magic things
Update... Spyder 3.3.6 is out 2019-07-16
Battle cry.... Install Spyder, Jupyter console and Jupyter notebook for ArcGIS Pro by default
Make it so.... now on to the content
Spyder... install once, use in multiple environments New... 2018-08-30
Table of contents: (use browser back to return here)
:--------- Latest Version
Version 3.3.6: installed 2019-07-16
Use proenv.bat and just ran..... conda update spyder
:--------- Installing Spyder in ArcGIS Pro
arcgis-pro-your-conda-environments
/blogs/dan_patterson/2018/12/28/clone
:--------- Some other links
Script documenting ... It is all in the docs - links to spyder help pane for user-created help.
Spyder on GitHub ... If you want to keep abreast of issues and/or enhancement requests
Spyder Documentation …. On GitHub or Spyder Documentation
Spyder-notebook ... Jupyter notebook inside Spyder...
... which can be arranged to suit
Yes from within Spyder, you can use Matplotlib or any other installed graphics pack (ie seaborn, orange etc)
Quickly navigate within them like a table of contents or use outline to get a basic shell listing of your script
The trick to outline is to use # ---- Your comment here 4 dashes seems to be the key for some reason
Change it
You can even pretty up the interface
/blogs/dan_patterson/2018/10/08/making-conda-package-installs-easier
More later
