Bug with GeometryEngine.Intersection in ESRI.ArcGIS runtime version 100.14.1
146
12-02-2022 03:01 AM
RobWag
New Contributor II
Hello everyone,
I discovered a bug in the ESRI.ArcGIS runtime version 100.14.1.
More specifically, it's about the GeometryEngine.Intersection function call, which constructs an intersection between two geometries.
This bug does not appear in ESRI.ArcGIS runtime version 100.9.0.
I wrote a small sample program that shows this bug. I pasted it below.
using Esri.ArcGISRuntime.Geometry;
namespace EsriIntersection
    public static class MySpatialReferences
        public static SpatialReference Mercator = new SpatialReference(102100);
        public static SpatialReference Wgs84 = new SpatialReference(4326);
    public class GeoPoint
        public double Latitude;
        public double Longitude;
        public double Altitude;
        public GeoPoint(double latitude, double longitude, double altitude)
            Latitude = latitude;
            Longitude = longitude;
            Altitude = altitude;
    public class Program
        private static void Main()
            List<GeoPoint> legGeoPoints = CreateLegGeoPoints();
            Geometry legGeometry = CreateLine(legGeoPoints);
            List<GeoPoint> baseGeometryGeoPoints = CreateBaseGeometryGeoPoints();
            Geometry baseGeometry = CreatePolygon(baseGeometryGeoPoints);
            Geometry resultPolygon = GeometryEngine.Intersection(baseGeometry, legGeometry);
            IReadOnlyList<ReadOnlyPart> lineParts = ((Polyline)resultPolygon).Parts;
            foreach (ReadOnlyPart part in lineParts)
                Console.WriteLine("Altitude: {0}", part.StartPoint.Z);
        private static List<GeoPoint> CreateLegGeoPoints()
            List<GeoPoint> legGeoPoints = new List<GeoPoint>();
            GeoPoint p1 = new GeoPoint(48.4165771802278, 11.4771135568153, 564.558573541593);
            GeoPoint p2 = new GeoPoint(48.4079168013471, 11.4661978649996, 564.558573541593);
            legGeoPoints.Add(p1);
            legGeoPoints.Add(p2);
            return legGeoPoints;
        private static List<GeoPoint> CreateBaseGeometryGeoPoints()
            List<GeoPoint> baseGeometryGeoPoints = new List<GeoPoint>();
            GeoPoint p1 = new GeoPoint(48.4258287904376, 11.4613346053484, 0);
            GeoPoint p2 = new GeoPoint(48.4258827480755, 11.4615642474136, 0);
            GeoPoint p3 = new GeoPoint(48.420352090187, 11.4784902184524, 0);
            GeoPoint p4 = new GeoPoint(48.4202261890318, 11.4785847769498, 0);
            GeoPoint p5 = new GeoPoint(48.40589144322, 11.4728032002502, 0);
            GeoPoint p6 = new GeoPoint(48.4058105067631, 11.4725465414715, 0);
            GeoPoint p7 = new GeoPoint(48.4125372256258, 11.4522704979526, 0);
            GeoPoint p8 = new GeoPoint(48.4126901056, 11.4521894478119, 0);
            baseGeometryGeoPoints.Add(p1);
            baseGeometryGeoPoints.Add(p2);
            baseGeometryGeoPoints.Add(p3);
            baseGeometryGeoPoints.Add(p4);
            baseGeometryGeoPoints.Add(p5);
            baseGeometryGeoPoints.Add(p6);
            baseGeometryGeoPoints.Add(p7);
            baseGeometryGeoPoints.Add(p8);
            return baseGeometryGeoPoints;
        private static Geometry CreatePolygon(List<GeoPoint> geoPointList)
            IEnumerable<MapPoint> mapPoints = geoPointList
                .Select(CreateMapPointFromGeoPoint);
            return new Polygon(mapPoints);
        private static Geometry CreateLine(List<GeoPoint> geoPointList)
            return new Polyline(mapPoints);
        private static MapPoint CreateMapPointFromGeoPoint(GeoPoint geoPoint)
            MapPoint mapPoint = new MapPoint(geoPoint.Longitude, geoPoint.Latitude, geoPoint.Altitude, MySpatialReferences.Wgs84);
            mapPoint = (MapPoint)GeometryEngine.Project(mapPoint, MySpatialReferences.Mercator);
            return mapPoint;
The program outputs the correct altitude "Altitude: 564,558573541593" in version 100.9.0.
In version 100.14.1 it outputs "Altitude: 0". ESRI.ArcGIS runtime version 100.15.0 does not fix this bug.
Do you know why this bug occurs and how I can bypass it so my program gets the correct height?
Thanks for your help in advance.
dotMorten_esri
Esri Notable Contributor
dotMorten_esri
RobWag
New Contributor II
Thanks for your reply. So it was unexpected behaviour before in version 100.9.0.?
