Path Distance problem
536
02-16-2023 03:34 AM
RobertoFilloramo
Good morning,
I am using Armap 10.8.2 and my issue is the result obtained from the path distance tool.
it appears a warning massage stating: Cost Cells with zero or negative values were encountered. Not all source cells may have been processed.
The used data are:
-shp point as origin;
-DTM (used as surface raster and vertical surface input);
-Slpoe (used as cost raster).
I used to process the same data in Arcmap 10 and I've never had this problem.
How can I fix it?
I attached an image of the result.
Thank you in advance
Bud
Notable Contributor
Bud
Notable Contributor
@DaraBurlo
Should this post be moved to the ArcMap community? https://community.esri.com/t5/arcmap/ct-p/arcmap
RobertoFilloramo
@RobertoFilloramo wrote:
Good morning,
The used data are:
How can I fix it?
thank you, I already posted in the ArcMap Community.
Sorry
