Firewall in ArcGIS Enterprise Deployment
898
11-22-2021 02:29 PM
IaraNascimento
After ArcGIS Enterprise is installed with the firewall turned off, can I re-enable the firewall on the physical machine where the VM where ArcGIS Enterprise is installed is located? ArcGIS Enterprise is installed on a VM.
George_Thompson
Esri Frequent Contributor
You will need to make sure that you have all the ports open for the product installed. Here is the information for Portal in terms of ports needed: https://enterprise.arcgis.com/en/portal/latest/install/windows/ports-used-by-portal-for-arcgis.htm
This information is available for each product in the installation guides: https://enterprise.arcgis.com/en/documentation/install/
--- George T.
JacobBoyle412
You can also review ports used by machine in this handy visualization:
https://enterprise.arcgis.com/en/system-requirements/latest/windows/pdf/ports-enterprise-deploy-dgm....
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
