Reuse of training samples (image classification) in different location?
536
12-04-2021 10:09 PM
JohanBaard
Hi
Can training samples (image classification) be reused in a different location from where it was captured?
The training samples are of two plant species and the procedure works well for the area the training was done in. The same species and age class will be searched in a similar area.
ArcGIS Pro 2.9     I do not have access to 'deep learning modules'.
Regards
DrVSSKiran
Occasional Contributor II
Yes, you can use the training dataset which is created for place "a" and you want to apply on place "c". But deep learning module is mandatory. You require image analyst extemsion for arcgis pro 2.9.
DanPatterson
Moved to Imagery and Remote Sensing Questions
... sort of retired...
DrVSSKiran
