What is the current optimal workflow for generating raster tiles in the compact V2 cache format at scale (i.e. 10 TB)?
My understanding is that the best method is to publish the imagery as an image service (ref mosaic dataset) to an Image Server. Subsequently, you can use manage map server cache to generate the cache using the server resources. Is this still valid? Or, are there other ArcGIS Pro tools that are more up to date and performant?
Yes there are multiple considerations with regards to design and storage but I wish to double check which geoprocessing workflow is currently the recommended process?
