Mosaic dataset symbology with mosaic dataset function problem
84
2 weeks ago
turkdomen
I have encountered a problem when trying to apply symbology to a mosaic dataset using Mosaic dataset function - Attribute table.
I have an 8-bit signed, single band mosaic dataset with 73 rasters, each with 6 classes. I want to apply symbology and label those classes to a layer using an Attribute table a Mosaic dataset function. The legend is ok, colors are ok, but they are not transparent.
Is there any way to set transparency and it will work correctly, or is the problem somewhere in mosaic creation or source rasters?
Ed_
by MVP Regular Contributor
Please see below, it may help, cheers.
Imagery appearance
turkdomen
Hey, Ed! That of course works, but I want to vary a transparency by attribute, so I would like to have it done with attribute rules instead, so it works immediately and you don't have to change it every time someone in my organization loads a mosaic to their Pro.
