EXPORTING SHAPE FILE ERROR
144
03-25-2023 05:43 AM
AlexanderTakele1
Hello community members,
I created training from worldview 2 images and tried to export it as shape file. but after exporting the training samples, the result is coming with .shp and xml file together  as show below in image . how can solve this? I want to upload this training samples to  and work with.
DanPatterson
MVP Esteemed Contributor
Close Pro and look at the folder again once the lock files are removed
... sort of retired...
AlexanderTakele1
Now LOCK file is removed after closing pro . but still xml is with .shp so that I cannot access this .shp file in colab.
I tried to run the code. but showing error '' incorrect file format or no such file directory''
DanPatterson
Export Training Data For Deep Learning (Spatial Analyst)—ArcGIS Pro | Documentation
I am not seeing shapefile as an output format...
