No attribute values are added to the measurement area feature measured and exported by the site scan.
I hoping to be added the result value of volume measurement as an attribute to the measurement area feature.
If it added the result value as an attribute value, we will be able to easier to use in other products immediately.
Thanks for sharing this idea @akari_namura. Could you please provide more context around your use case for this, describe how you are achieving this today, and what other products you intend to use this in?
Hello @NicoBonnafoux ,
We measured the volume values by Site Scan and manages it as progress rate in the ArcGIS Dashboards.
Currently, we are implementing the following workflow.
1. share the visible of the measurement area to ArcGIS Online.
2. display the volume area on the ArcGIS Dashboards.
3. we enter the measured volume value manually in ArcGIS Dashboard.
4. We are able to manage the progress of construction (cut/fill)
Adding a volume value as an attribute value makes it immediately easier to use in ArcGIS Dashboard, No manual operation is required.
Thank you for providing additional details @akari_namura.
We'll consider this capability as a future enhancement and let you know if/when it makes it in the product plan.
I encourage anyone who has similar needs to share their feedback and use cases here.
Thanks!
Nico
