Site Scan Flight for ArcGIS – Matrix of Supported Drones, Cameras, and Lenses
10173
12
12-14-2020 04:15 PM
JavierSosa
6 12 10.2K
This resource describes the vehicles, cameras, and lenses that are supported by the Site Scan Flight app. It also includes the latest firmware version tested and supplemental information regarding camera configurations. (This document is kept up-to-date. Last updated: April 14, 2022)
  • Note: This resource applies to the Site Scan Flight app only. Georeferenced images from a flight conducted with a drone not on this matrix may still be uploaded to Site Scan Manager for ArcGIS for processing and analysis.
Recommended Drones
DJI Phantom 4 Pro (v1 or v2)
  • Industry-standard
  • Popular drone series for a wide range of projects
DJI Mavic 2 Pro
  • Low-cost
  • Compact
  • Less accurate than Phantom 4 Pro due to rolling shutter camera
DJI Phantom 4 RTK with SDK controller
  • High geolocation accuracy minimizes the need for ground control points
  • Factory calibrated camera
DJI Matrice 200 v2
  • Rugged and weatherproof (IP43 Rating)
  • Supports X7 24 MP camera with a mechanical shutter
  • Supports XT2 thermal and visible spectrum sensor
Supported Drones
Vehicle
Supported Firmware
Supported Cameras/Lens Configurations
Notes
DJI Phantom 4 Advanced
01.00.0600 & 01.00.0128
Fixed Camera
DJI Phantom 4 Pro
v01.05.0300 & v01.05.0600
Fixed Camera
- Phantom 4 Pro “+” (Plus) version with controller with a built-in screen is not supported
DJI Phantom 4 Pro v2
v01.00.5000 & v01.00.5200
Fixed Camera
DJI Phantom 4 RTK
v02.02.0503 & v02.02.0607
Fixed Camera
- Requires SDK controller, controller with built in screen is not supported
DJI Mavic Pro
v01.04.0400 & v01.04.0500
Fixed Camera
- Not recommended for high-accuracy mapping
DJI Mavic 2 Pro
01.00.0670 & 01.00.0770
Fixed Camera
DJI Matrice 200
01.02.0301 & 01.02.0450
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT Radiometric Temperature Camera (640 X 512, 30 HZ, 13MM)
DJI Matrice 210
DJI Zenmuse X4S
DJI Zenmuse X5S
Dual Configuration:
- DJI Zenmuse X4S + DJI Zenmuse XT Radiometric Temperature Camera (640 X 512, 30 HZ, 13MM)
DJI Matrice 210 RTK
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT Radiometric Temperature Camera (640 X 512), 30 HZ, 13MM)
Dual Configuration:
DJI Matrice 200 v2
01.00.0590 & 01.00.0710
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT 2
DJI Zenmuse X7
DJI Matrice 210 v2
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT 2
DJI Zenmuse X7
Dual Configurations:
- DJI Zenmuse XT 2 + DJI Zenmuse X7
DJI Matrice 210 RTK v2
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT 2
DJI Zenmuse X7
DJI Matrice 300 RTK
03.00.0101 & 03.01.0014
DJI Zenmuse P1
DJI Inspire 2
01.02.0500 & 01.02.0600
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse X7
Supported Cameras
Camera
Specifications (recommended configurations)
Notes
P4A Camera
Sensor: 1” CMOS
Effective pixels: 20M
Lens Field of View (FOV): 84°
Focal Length: 8.8 mm / 24 mm (35 mm format equivalent)
Aperture: f/2.8-f/11
Shutter: Mechanical
Fixed camera
P4P Camera
Sensor: 1” CMOS
Shutter: Mechanical
Fixed camera
P4Pv2 Camera
Sensor: 1” CMOS
Shutter: Mechanical
Fixed camera
P4RTK Camera
Sensor: 1” CMOS
Shutter: Mechanical
Fixed camera
Mavic Pro Camera
Sensor: 1/2.3” CMOS
Effective pixels: 12.35M (Total pixels:12.71M)
Lens Field of View (FOV): 78.8°
Focal Length: 26 mm (35 mm format equivalent)
Aperture: f/2.2
Shutter: Electronic
Fixed camera
Mavic 2 Pro Camera
Sensor: 1” CMOS
Effective Pixels: 20M
Lens Field of View (FOV): ~77°
Focal Length: 28 mm (35 mm format equivalent)
Shutter: Electronic
Fixed camera
X4S
Sensor: 1” CMOS
Aperture: f/2.0
Shutter: Leaf
X5S
Sensor: 4/3” CMOS
Effective Pixels: 20.8M
Focal Length: 15 mm / 30 mm (35 mm format equivalent)
Aperture: f/2.0-f/22
Shutter: Electronic
-  The lens listed is the recommended lens. Other lenses may function but will require manual focal length input in Advanced Flight Planning settings to correctly calculate overlap and sidelap.
XT Version: Radiometric
Lens Field of View (FOV): 45°
Lens: 13 mm Camera Lens
Max Thermal Frame Rate: 30 HZ
Resolution: 640x512
Shutter: Mechanical
DJI Zenmuse XT 2
Sensor: 1/1.7" CMOS
Thermal Imager: Uncooled VOx Microbolometer
Lens Field of View (FOV): 45° x 37°
Effective Pixels: 12M
Max Thermal Frame Rate: 30HZ
Resolution: 640x512
Shutter: Mechanical
DJI Zenmuse X7
Effective Pixels: 24M
Sensor Size (Still): 23.5×15.7 mm
Sensor Size (Max video recording area): 23.5×12.5 mm
Supported Lens: DJI DL 24 mm F2.8 LS ASPH (with lens hood and balancing ring/filter) / 36 mm (35 mm format equivalent)
Shutter: Mechanical
DJI Zenmuse P1
Effective Pixels: 45M
Sensor Size (Still): 35.9×24 mm
Sensor Size (Max video recording area): 34×19 mm
Lens Field of View (FOV): 63.5°
Supported Lens: DJI DL 35mm F2.8 LS ASPH (with lens hood and balancing ring/filter)
Shutter: Mechanical
Tags (1)
12 Comments
