Mosaic Datasets created or edited with Pro 2.3.2
1674
03-28-2019 02:29 PM
by Anonymous User
Not applicable
3 4 1,674
The ArcGIS Pro 2.3.2 software patch enables mosaic datasets created or modified by Pro 2.3 and 10.7 to be read and modified by earlier versions (ArcGIS Pro 2.1 and 10.5 or later).
If you created or modified a mosaic dataset using Pro 2.3 or 10.7, you can update it and make it compatible with earlier versions by following the steps below.
  1. Open Pro 2.3.2.
  2. In the Catalog pane, navigate to your mosaic dataset. Right-click and select Properties from the drop-down menu.
  3. Click Defaults which displays Image Properties. Scroll down to Maximum Number of Rasters Per Mosaic, and change the value to any number. Press <Tab> to update the field.
  4. Change the Maximum Number of Rasters Per Mosaic property back to the original value and press <Tab> to update the field again.
This resets the mosaic dataset object to the new Pro 2.3.2 version.
Update to ArcGIS Pro 2.3.2 by going to My Esri or by using the in-app software updater.
4 Comments
