Real-time Geodatabase Replication? Part 6
697
01-01-2015 12:25 PM
ThomasColson
3 0 697
Schema Changes
In Arc Catalog add a new field to the local instance of FISH.
fewtrew.JPGIn the Replication Monitor you should see that schema change fire to the remote database within 60 seconds.
dsatrfew.JPGIn the remote instance of TEST you should see "ANEWFIELD" in its properties in Arc Catalog. Make some attribute edits to this field on the local instance and watch them fire.
Here's why we created an empty version of TEST on the remote SDE instance and ONLY replicate the TEST table. In the SDE "stack" there are lots and lots and lots of tables, functions, and stored procedures that handle things. Had we attempted to replicate TEST from the Publisher to the Subscriber without first having created the TEST feature class on the subscriber, none of the SDE dependencies would have been created and we wouldn't be able to use the remote TEST feature class in any GIS applications.
In this manner we can have a fully synchronized copy of TEST on both SDE instance yet the SDE "stack" on either instance independently manages the feature class without any interference caused by replication.
Real-time Geodatabase Replication? Part 1
Real-time Geodatabase Replication? Part 2
Real-time Geodatabase Replication? Part 3
Real-time Geodatabase Replication? Part 4
Real-time Geodatabase Replication? Part 5
This is a personal blog and does not recommend, endorse, or support the methods described above. Alteration of data using SQL outside of the ESRI software stack, of course, is not supported and should not be applied to a production database without a thorough understanding and disaster recovery plan.
About the Author
This is a personal account and does not reflect the view or policies of my org.
