Real-time Geodatabase Replication? Part 5
892
01-01-2015 12:26 PM
ThomasColson
3 0 892
Testing CRUD Operations on the Publisher
Lets make some edits on the Publisher (local) SDE and see if they show up on our remote SDE instance.
In order to edit non-versioned data you will need to set your editor options to allow un-versioned editing:
In Arc Map, add one point to the local FISH feature class. In the Replication Monitor you should see that insert fire to the remote database within 60 seconds.
If you add the remote FISH feature class to Arc Map you should see the exact same point.
Perform an attribute edit of the new point. In the Replication Monitor you should see that update fire to the remote database within 60 seconds.
Delete the point. In the Replication Monitor you should see that delete fire to the remote database within 60 seconds.
Real-time Geodatabase Replication? Part 1
Real-time Geodatabase Replication? Part 2
Real-time Geodatabase Replication? Part 3
Real-time Geodatabase Replication? Part 4
Real-time Geodatabase Replication? Part 6
This is a personal blog and does not recommend, endorse, or support the methods described above. Alteration of data using SQL outside of the ESRI software stack, of course, is not supported and should not be applied to a production database without a thorough understanding and disaster recovery plan.
About the Author
This is a personal account and does not reflect the view or policies of my org.
