Project Raster - WGS1984 to RGPF - Transformation not applied
229
10-05-2022 04:38 PM
BenjaminBigarre
Hi all.
I am using ArcGIS Pro 3.0.2
I am trying to reproject a raster from WGS1984 to RGPF. The Project Raster tool runs smoothly but the projected raster is still off, like the original raster.
When checking the spatial reference of the projected raster, it indicates the correct projected coordinate system /geographic system. However it's still not aligning with the other layers, which are in the RGPF system.
Here is the log from the Geoprocessing tool
Project Raster
Parameters
Input Raster 01881RC_IRD_PYF_PEDO_1996_40000.ERS
Output Raster Dataset C:\Users\bigar\OneDrive - CSULB\Benji_Documents\ArcGIS\Projects\Moorea_NEW\Moorea_NEW.gdb\c01881RC_IRD_P_ProjectRaster1
Output Coordinate System PROJCS["RGPF_UTM_Zone_6S",GEOGCS["GCS_RGPF",DATUM["D_Reseau_Geodesique_de_la_Polynesie_Francaise",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",10000000.0],PARAMETER["Central_Meridian",-147.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Resampling Technique NEAREST
Output Cell Size 5.0598846115969 5.05988461159723
Geographic Transformation RGPF_To_WGS_1984_1
Registration Point
Input Coordinate System GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
Vertical NO_VERTICAL
Environments
Geographic Transformations RGPF_To_WGS_1984_1
Messages
Start Time: Wednesday, October 5, 2022 4:21:25 PM
Succeeded at Wednesday, October 5, 2022 4:21:33 PM (Elapsed Time: 7.37 seconds)
And a screenshot
