I'd like some Python to export multiple raster tables, with the same attributes, and append into a single txt (or similar) file please.
The only way currently is to open each table and either cut and paste the data or export each table into single files, then open and combine in excel. Takes ages.
There used to be a command called "unload" in ArcInfo I used years ago.
or I'd even be happy with a model builder solution??
