arcgis.features and GeoAccessor error when trying to do import after update to 3.4
100
4 weeks ago
GISDepartmentMFM
hello,
I have been using from arcgis.features import GeoAccessor, GeoSeriesAccessor to make my layers from data frame for a good while now. However after updating to 3.4 when I try to import the following error occurs :
  File "<string>", line 1, in <module>
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\__init__.py", line 3, in <module>
    from arcgis.auth.tools import LazyLoader
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\auth\__init__.py", line 1, in <module>
    from .api import EsriSession
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\auth\api.py", line 8, in <module>
    from ._auth import (
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\auth\_auth\__init__.py", line 2, in <module>
    from ._pki import EsriPKIAuth
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\auth\_auth\_pki.py", line 4, in <module>
    from ..tools._lazy import LazyLoader
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\auth\tools\__init__.py", line 1, in <module>
    from .certificate import pfx_to_pem
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\auth\tools\certificate.py", line 9, in <module>
    from cryptography import x509
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\cryptography\x509\__init__.py", line 7, in <module>
    from cryptography.x509 import certificate_transparency, verification
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\cryptography\x509\certificate_transparency.py", line 8, in <module>
    from cryptography.hazmat.bindings._rust import x509 as rust_x509
ImportError: DLL load failed while importing _rust: The specified procedure could not be found.
I have tried doing the import on a different computer that also has 3.4 and there is no error I fear that I may have to do a reinstall however I came here before doing that just incase there is a better option  before doing that.
Tags (3)
DanPatterson
see your duplicate thread
arcgis.features and GeoAccessor error when trying ... - Esri Community
... sort of retired...
