Address Locator - Default Field Map Value
80
3 weeks ago
JoshBillings
Hi all,
I am creating a point address locator and one of the requirements is that "State" is part of the locator. My problem is that the address data that is being used for this locator doesn't contain a "State" field. However, all data in this locator is from the same state.
I can't manipulate the data as it is and want to refrain from having to export this data out to add/populate a new field.
Is there a way that I can set a default field map value when creating the locator?
Thanks!
Josh
