Filter lists with custom input
1119
08-30-2018 02:39 AM
RiccardoKlinger2
I've created a small toolbox where I use a GPString input with a filter list:
        param1 = arcpy.Parameter(
            displayName="OSM tag value",
            name="in_key",
            datatype="GPString",
            parameterType="Required",
            direction="Input",
            multiValue=True
        param1.filter.list = self.getConfig("tags")
the function getConfig reads a JSON and fills the values of the String input. Yet I want to enable the user to use an own string for the input at param1.
Is there any chance to do this with the given approach or do I need to create a second input for a user defined GPString?
Here is the issue on GitHub: allow manual input of tags and keys · Issue #16 · riccardoklinger/OSMquery · GitHub
