Let's start with the result:
One of the major questions of a location is: What/Whome can I reach in
Using a normal network would not alter the service areas during the day but by using the ArcGIS Online network dataset based on HERE data we can also use the traffi patterns for a day of the week and a given time. Traffi patterns can be analyswed in a 15min period. Analyzing the service areas during a day provides a valuable insight into the traffic situation of a region: big differences indicate first of all higher traffic volume on streets. The total area also indicates the quality of the network: large areas indicate a better accessibility using the car (maybe caused by a dense network of high-speed streets).
As I love geoprocessing, I was interested in the automation of the analysis and the visualisation as an animation. The process is therfore a two-stepped one.
First I created a simple point feature class called "StartPoints" which holds the locations of the "facilities" and added them to the Service Area Analysis Layer:
#create Analysis Layer
arcpy.na.MakeServiceAreaAnalysisLayer("https://www.arcgis.com/", "BeatCity Service Layer", "Driving Time", "FROM_FACILITIES", "5;10;15;20;25;30", "05.01.1900 00:01:00", "LOCAL_TIME_AT_LOCATIONS", "POLYGONS", "STANDARD", "DISSOLVE", "RINGS", "100 Meters", None, None)
#add locations from a point feature class
arcpy.na.AddLocations("BeatCity Service Layer", "Facilities", "StartPoints", "Name Description #;CurbApproach # 0;Attr_Minutes # 0;Attr_TravelTime # 0;Attr_Miles # 0;Attr_Kilometers # 0;Attr_TimeAt1KPH # 0;Attr_WalkTime # 0;Attr_TruckMinutes # 0;Attr_TruckTravelTime # 0;Breaks_Minutes # #;Breaks_TravelTime # #;Breaks_Miles # #;Breaks_Kilometers # #;Breaks_TimeAt1KPH # #;Breaks_WalkTime # #;Breaks_TruckMinutes # #;Breaks_TruckTravelTime # #", "5000 Meters", None, None, "MATCH_TO_CLOSEST", "APPEND", "SNAP", "5 Meters", "EXCLUDE", None)
Now we need to alter the times automatically to refelct the times of day. The start time is '05.01.1900 00:00:00' which is a Friday and the time is midnight.
We can access the properties quite easily. As I am working with a 3D scene this is my only map object in my ArcGIS Pro project:
#get the project
doc = arcpy.mp.ArcGISProject('current')
#get the map
map = doc.listMaps()[0]
#get the service area layer
sa_layer = map.listLayers("BeatCity Service Layer")[0]
#Get the solver properties object from the service area layer
solver_props = arcpy.na.GetSolverProperties(sa_layer)
As we now have access to the properties we can easily iterate and solve the service layer. The result will be exported as a 3D feature class:
import os
for hour in range(0,24):
#create the datetime object
date = datetime.datetime(1900, 01, 05 , hour,0,0)
#we will use the string-version later on
datestring = date.strftime("%d.%m.%Y %H:%M")
#set the time of the day and the date:
solver_props.timeOfDay=date
#solve the network layer
arcpy.na.Solve("BeatCity Service Layer", "SKIP", "TERMINATE", None, None)
arcpy.AddMessage("copying hour" + str(hour))
#as we would like to visualize this in 3D
arcpy.ddd.FeatureTo3DByAttribute(r"BeatCity Service Layer\Polygons", arcpy.env.workspace + os.sep + "Friday_" + str(hour), "ToBreak", "ToBreak")
#and add a field with the date for later usage if wanted:
arcpy.AddField_management(arcpy.env.workspace + os.sep + "Friday_" + str(hour), "datetime","Date","", "",8, "datetime", "NULLABLE", "REQUIRED")
arcpy.management.CalculateField(arcpy.env.workspace + os.sep + "Friday_" + str(hour), "datetime", '"' + datestring + '"', "PYTHON_9.3")
Warning: Solving the layer consumes credits!
The results are stored in seperate feature classes which is not optimal yet this is my solution at the very moment. For
As we have seperate layers now I am applying the same style to all of them and triggering the visibility of each layer and exporting the layout which needs to be created prior the export!
My Layout looks something like this:
I added a text symbol with a default Text "Friday" in the layout to export the timestamp in the png result as well. Furthermore I added a marker symbol with the cities name to the layout and tilted the view a bit to increase the depth effect for the extruded layer. But first we need to disable all layers for our automated export with a quite unsophisticated approach:
#deselcting all layers:
for layer in map_obj.listLayers():
if layer .name[0] == "F":
layer .visible = False
Now we can iterate through the layers, apply the unique value renderer, alter the symbols to get polygons without borders, set the extrusion, alter the text element to get the right timestamp and export the layout as png:
poly_layer = map_obj.listLayers("Friday_" + str(hour))[0]
poly_layer.visible = True
symbology = poly_layer.symbology
symbology.updateRenderer('UniqueValueRenderer')
symbology.renderer.fields = ['ToBreak']
symbology.renderer.colorRamp = doc.listColorRamps('Green-Blue (6 Classes)')[0]
#alter all symbols:
for sym in symbology.renderer.groups[0].items:
sym.symbol.outlineColor = {'RGB': [255, 255, 255, 0]}
sym.symbol.size = 0.0
poly_layer.symbology = symbology
#extrude:
poly_layer.extrusion('BASE_HEIGHT', "3000-100*[ToBreak]")
#export:
datestring = "2017/12/08 " + str(hour) + ":00"
for lyt in doc.listLayouts():
for elm in lyt.listElements("TEXT_ELEMENT"):
if elm.text[0] == "2":
elm.text = datestring
lyt.exportToPNG(arcpy.env.workspace + os.sep + "friday_seattle_final" + str(hour) + ".png", 300)
poly_layer.visible = False
Unfortunately the whole rendering and exporting process takes about 2.5minutes per scene on my Lenovo X270 with no dedicated GPU.
The result is a bunch of pngs that can be converted intzo a gif using several gif-creation sites on the web or the open source image editor GIMP.
The result looks like this:
You can also append all polygon features from the result, add the datetime attribute, fill the used time, time-enable the feature class, and use the animation options in ArcGIS Pro to export the whole animation as a GIF:
The result looks quite similar to the file-wise export. Yet you don't have all the possibilities of the layout view. But still the result is quite good (added 5, 10, 15, 20 mil buffers):
