Upgrading Enterprise Geodatabase from 10
260
a month ago
AndreaB_
Occasional Contributor II
Hello all,
I have a SQL geodatabase in SQL Server 2022 with 2019 compatibility at geodatabase version 10. So a very old geodatabase version. We are using ArcMap 10.8.2 and ArcGIS Pro 3.2.2 with ArcGIS Enterprise 11.1 with Portal.
I'm looking for upgrade advice:
From previous community research it looks like I need to use ArcGIS Pro 2.9 to upgrade the geodatabase version to 10.9.1.2.9 to work with ArcMap 10.8.2. Is that right?
Can I go straight from 10 to 10.9.1.2.9 or do I have to do some in-between version upgrading?
Any other thoughts or suggestions?
Thank you,
Andrea
Tags (3)
2 Solutions
George_Thompson
Esri Frequent Contributor
It looks like from v10.0 (any patch level) you will need to upgrade to 10.3 first; https://desktop.arcgis.com/en/arcmap/10.3/manage-data/gdbs-in-sql-server/upgrade-geodatabase-sqlserv...
Then move to Pro 2.8.x: https://pro.arcgis.com/en/pro-app/2.8/help/data/geodatabases/manage-sql-server/upgrade-geodatabase-s...
Then you can go to Pro 2.9.x: https://pro.arcgis.com/en/pro-app/2.9/help/data/geodatabases/manage-sql-server/upgrade-geodatabase-s...
Because you are so many versions behind, you would have to make 2 - 3 jumps. You may be able to do this with another ArcMap client version instead of Pro, but would recommend lots of research and planning to make this drastic of a change.
--- George T.
MarceloMarques
@AndreaB_ - if possible, it might just be easier if you create a new empty SQL Server Geodatabase with ArcGIS Pro 3.2.2, and then reload the data from the old 10.0 geodatabase into the new geodatabase.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
George_Thompson
--- George T.
MarceloMarques
AndreaB_
Thank you both! Really great info @George_Thompson. Yeah, @MarceloMarques , that thought had crossed our minds also. I'll be trying that in a dev environment and see if that works. We would have to put the permissions back in place but I think our DBA can help with that part of it.
