Oracle Geodatabase upgrade issue - Version 11.3
134
Wednesday
Felipe
Hello Community,
I am trying to upgrade an Enterprise Geodatabase from the version 11.1 to the version 11.3, running on Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production
Version 19.24.0.0.0.
But I am receiving the following error:
Could not upgrade multiple schema or database instance. [The master geodatabase contains user schema geodatabases which should be upgraded separately after the master geodatabase is upgraded.
Id Version Instance
It is weird because I am connected with the SDE user and I am sure that it is the master geodatabase schema.
Is there an efficient way to query this error in the database admin tables?
I already upgraded other geodatabases using the same ArcGIS Pro installation, and it worked normally. It discarded the possibility to be a problem with the ArcGIS Pro, Oracle client or Oracle version.
Did somebody had similar issue recently?
Any help would be much appreciated.
Thank you.
KR
Felipe
VinceAngelo
Esri Esteemed Contributor
User schema geodatabases have been deprecated for more than four years. Are you sure this is even possible?
- V
Felipe
Hi @VinceAngelo , thank you for your answer!
Indeed, it is very strange, and the message shows an empty list when I get the error:
More or less 6 months ago, this database has been successfully upgraded from 10.9.1 to 11.1, with no errors:
Do you think the error is coming from some corrupted table?
Thank you!
VinceAngelo
I think the deprecation is being enforced by 3.3/10.3.
- V
MarceloMarques
Hello @Felipe
Esri User-Schema Geodatabases in Oracle are deprecated.
Read more in the blog articles below.
ArcSDE User-Schema Geodatabases in Oracle are deprecated
Oracle 23ai (23c) Support for ArcGIS
Enterprise Geodatabase in Oracle CDB & PDB - Best Practices and Recommendations
Regards,
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 32 years, my passion for GIS has only grown stronger." | “ I do not fear computers. I fear the lack of them." Isaac Isimov |
