Differences in Geodatabase upgrade using ArcGIS Pro Vs ArcMap
1051
08-08-2022 01:14 AM
Ranga_Tolapi
Occasional Contributor III
What would be the behavioral differences in the Upgraded Geodatabase, when it's upgraded using the below 2 approaches.
Source Geodatabase (version 10.6): Oracle 12c
Target Geodatabase: Oracle 19c
  1. Upgrade Geodatabase using ArcMap 10.8.1
  2. Upgrade Geodatabase using ArcGIS Pro 3.0
2 Solutions
JakeSkinner
Esri Esteemed Contributor
@Ranga_Tolapi the version of the geodatabase would be different.
ArcMap 10.8.1 will upgrade your geodatabase to version 10.8.1.
ArcGIS Pro 3.0 will upgrade your geodatabase to version 11.0.0.
MarceloMarques
Client and geodatabase compatibility—ArcGIS Pro | Documentation
Geodatabase version | ArcGIS Pro release | Equivalent 10.x or 11.x release
10.6.1.2.2
2.2
10.6.1
10.7.0.2.3
2.3
10.7
10.7.1.2.4
2.4
10.7.1
10.8.0.2.5
2.5
10.8
10.8.1.2.6
2.6
10.8.1
10.9.0.2.7
2.7
10.9
10.9.0.2.8
2.8
10.9
10.9.1.2.9
2.9
10.9.1 and 10.8.2
11.0.0.3.0
3.0
11.0
if you check the geodatabase version after the sde repository upgrade with ArcGIS Pro 3.0 you will notice that the geodatabase version displays as 11.0.0.3.0, you can also query the table "sde.version".
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
DanPatterson
MVP Esteemed Contributor
Upgrade Geodatabase (Data Management)—ArcGIS Pro | Documentation
Upgrade a geodatabase in Oracle—ArcGIS Pro | Documentation
These are the help topics for Pro 3.0.  Compare to what arcmap does.
There is no inter-version document comparisons
... sort of retired...
JakeSkinner
MarceloMarques
10.6.1.2.2
2.2
10.6.1
10.7.0.2.3
2.3
10.7
10.7.1.2.4
2.4
10.7.1
10.8.0.2.5
2.5
10.8
10.8.1.2.6
2.6
10.8.1
10.9.0.2.7
2.7
10.9
10.9.0.2.8
2.8
10.9
10.9.1.2.9
2.9
10.9.1 and 10.8.2
11.0.0.3.0
3.0
11.0
