Automating Data Updates Between Related Tables in ArcGIS Pro
77
2 weeks ago
JEMOO-01
Hi everyone,
I'm currently working on a project in ArcGIS Pro and need some assistance with automating data updates between two related tables in my geodatabase. Here's the scenario:
Scenario:
  • Table 1:
    • Contains several material fields (TYPE_A, TYPE_B, TYPE_C, TYPE_D).
    • Has a calculated Total field that sums up these material fields.
    • I want changes in this Total field to trigger updates in Table 2.
  • Table 2:
    • Contains a Total_Available_Material field.
    • This field should reflect the same value as the Total field in Table 1, automatically updating whenever the Total in Table 1 changes [ Without Use Triggers in the table ( insert or update ) ]
Objective:
  • Ensure that any changes in the material fields in Table 1 automatically update the Total_Available_Material field in Table 2.
  • Maintain data consistency across both tables without manual intervention.
Steps I Have Taken:
  1. Created a Relationship Class:
    • Established a relationship class between Table 1 and Table 2 using a common field (ID).
    • The Relationship Class was Simple and one to one.
  2. Set Up Attribute Rules:
    • In Table 1: Created an attribute rule to calculate the total of material fields and intended to update Table 2.
    • In Table 2: Created an attribute rule to update the Total_Available_Material field based on changes in Table 1.
Arcade Expression Used:
In Table 1:
// Calculate the total of material fields in Table 1
var totalMaterial = $feature.TYPE_A + $feature.TYPE_B + $feature.TYPE_C + $feature.TYPE_D;
// Store the total in the Total field of Table 1
$feature.Total_Available_Material== totalMaterial;
// Retrieve the related records from Table 2 using the relationship class
var related_records = FeatureSetByRelationshipName($feature, "RelationShipClass");
var related_record = First(related_records);
// Update the Total_Available_Material field in Table 2
if (!IsEmpty(related_record)) {
related_record.Total_Available_Material = totalMaterial;
return totalMaterial;
} else {
return totalMaterial; // Return the total if no related record is found
Issues Encountered:
  • The attribute rule in Table 1 does not seem to trigger the update in Table 2 automatically.
  • Unsure of the best approach to ensure that updates in Table 1 are reflected in Table 2 without manual intervention.
Request for Help:
  • How can I modify my approach or the Arcade expressions to achieve the desired automated updates between these two tables?
  • Any best practices or tips for setting up such dependencies between related tables in ArcGIS Pro?
*Notice
If the scenario wasn't clear easily want to force attribute rule to work without using triggers [ update , insert ]
Thank you in advance for your help!
Best regards, [JIMMY]
