Attribute Rule - Calculation Type - Not working
272
10-29-2021 02:15 PM
Raj-Chavada
New Contributor III
Hello,
We have two feature classes A & B in enterprise geodatabase environment. They are participating in a relationship class.
A - Projects
B- Sewer upgrades
Our goal/requirement is to automatically update the common attributes on existing features in B if the same attribute fields are updates in A.
To accomplish this, base on the example available here, I came up with following (immediate calculation rule on A):
//s1 - get all the features from sewer upgrades feature class
var destination = FeatureSetByName($datastore, "GEO_DB.ENG_SD.SewerUpgrade", ["DBNUMBER","TECH_REV", "CONS_ST", "CONS_ED", "EST_CON_DUR", "STATUS"], false);
//s2 - get dbnumber edited in the projects developments feature class
var dbnumber = $feature.DBNUMBER;
//s3 - filter feature based on the existing edit
var match = Filter(destination, "DBNUMBER = @dbnumber");
//s4 - update records in sewer upgrades
var sewerupgradelist = [];
var counter = 0;
var numfeatures = Count(match);
if (numfeatures > 0) {
    for (var feature in match)  {
           sewerupgradelist[counter] = {
                'OBJECTID' : feature.OBJECTID,
                'attributes' : {
                         'CONS_ST' : $feature.CONS_ST,
                         'CONS_ED' : $feature.CONS_ED,
                     'EST_CON_DUR' : $feature.EST_CONS_DUR,
                        'TECH_REV' : $feature.TECH_REV,
                          'STATUS' : $feature.STATUS
                     counter++
                  return {
                         'result' : numfeatures + ' sewer upgrades features found.',
                          'edit' : [{
                               'className' :  "GEO_DB.ENG_SD.SewerUpgrade",
                                'updates' :   sewerupgradelist
  }else {
    return 'No features found under sewer upgrade with matching DBNUMBER.'
While there are no validation errors, ArcGIS Pro comes up with following error during testing:
Any help in resolving the issue will be appreciated.
JohannesLindner
According to the documentation of the attribute rule dicitonary keywords ,
  • the "result" field in the returned dictionary is either
    • a value for the field definied as return field for the rule
    • a dicitionary for the geometry and/or attributes of the feature, if you haven't set a return field in the rule
  • You return a log message. If you haven't set a text field as output field of the rule, this should throw an error.
  • The ObjectID in the update array should be given in the dictionary field "objectID", not "OBJECTID", don't know if this would cause an error, though.
So, try this:
// you only need DBNUMBER (to filter) and OBJECTID (to send edits)
var destination = FeatureSetByName($datastore, "GEO_DB.ENG_SD.SewerUpgrade", ["DBNUMBER","OBJECTID"], false);
var counter = 0;
        'objectID' : feature.OBJECTID,
        'attributes' : {
    counter++
return {
// only use this if you have set a text field as return field for the rule
//    'result' : numfeatures + ' sewer upgrades features found.',
    'edit' : [{
Have a great day!
Johannes
Mike_I
by Esri Contributor
Hello Raj-Chavada,
I'm not sure this is the reason for the error message, but I see something I'd like to ask about:
At Line 2, in your field list, I see 6 fields: "DBNUMBER", "TECH_REV", "CONS_ST", "CONS_ED, "EST_CON_DUR", and "STATUS"
In Lines 20-25, I see 6 fields: 'CONS_ST', 'CONS_ED', 'CONS_ST', 'EST_CON_DUR', 'TECH_REC', and 'STATUS'
  • In these lines of code, 'CONS_ST' is referenced 2x while 'DBNUMBER' is not referenced.
  • Is this by design?
  • Is it possible 'DBNUMBER' is meant to be referenced, but the 2x 'CONT_ST' is causing confusion, and that is the reason for the error?
What do you think?
Regards,
Mike
Data Management Specialist, Esri Support Services
Raj-Chavada
New Contributor III
Thanks, Mike! Please see my reply below:
  • In these lines of code, 'CONS_ST' is referenced 2x while 'DBNUMBER' is not referenced. Is this by design?
RC: No. This is an error on my part. Removed the extra line.
RC: I am not referencing 'DBNUMBER' because that attribute field not required to be updated.
JohannesLindner
So, try this:
var counter = 0;
        'attributes' : {
    counter++
return {
    'edit' : [{
Have a great day!
Johannes
Raj-Chavada
New Contributor III
Thank you so much! This worked. Accepting as solution.
