Use data source as third-party libary input (Experience Builder Developer)
314
02-28-2023 01:20 AM
OttK
New Contributor II
Hi
I'm looking into how to add third-party library chart to Experience Builder as a widget. I've tested with d3 library chart sample code (arcgis-experience-builder-sdk-resources/widgets at master · Esri/arcgis-experience-builder-sdk-resou...) with static input as in the example.
What I would eventually like to have is following.
App with a map widget, configure filter data records action on map widget, use map widget's data source as input to d3 library chart so that when map view changes then third-party chart data also changes.
I've tried looking into other widgets sample code like "listen selection change of a data source" (arcgis-experience-builder-sdk-resources/widgets at master · Esri/arcgis-experience-builder-sdk-resou...) and how these get input data from data source but haven't figured out a way to do that with d3 chart.
Has anyone tried to do similar solution and can nudge me in the right direction on how to use data source with third-party library charts?
Thanks
Junshan_Liu
The most common way to access data is to use the DataSourceComponent. With this component, you can get the DataRecords, then you can pass the data to the d3.
