In JavaScript/Typescript you might take advantage of the reduce method (granted that 1 liner in python is freaking cool @MikeMillerGIS
Here are two possibilities, one uses an NPM library called lodash the other looks is plain JS/Typescript (no new library needed to install)
JavaScript/Typescript using NPM library lodash (the _ is the import name for lodash in this case)
import _ from "lodash";
function summarizeArray(arr: string[]): string {
// Step 1: Count occurrences using _.countBy
const counts = _.countBy(arr);
// Step 2: Sort keys alphabetically and format the result
const summary = _(counts)
.toPairs() // Convert object to array of [key, value] pairs
.sortBy(0) // Sort by the key (fruit name)
.map(([fruit, count]) => `${fruit} x ${count}`) // Format each pair
.join(", "); // Join into a single string
return summary;
// Example usage
const fruits = ["Apples", "Bananas", "Berry", "Bananas", "Apples", "Bananas"];
const result = summarizeArray(fruits);
console.log(result); // Output: "Apples x 2, Bananas x 3, Berry x 1"
JavaScript/TypeScript with no additional library needed
// Step 1: Count occurrences of each item
const counts = arr.reduce((acc, fruit) => {
acc[fruit] = (acc[fruit] || 0) + 1;
return acc;
}, {} as Record<string, number>);
// Step 2: Sort the keys alphabetically
const sortedKeys = Object.keys(counts).sort();
// Step 3: Map to the desired format
const summary = sortedKeys.map(key => `${key} x ${counts[key]}`).join(", ");
return summary;
// Example usage
