VMap with ArcMap Desktop 10.2
1551
03-17-2021 09:53 AM
BenLeslie1
Should I be able to load VMap in ArcMap Desktop 10.2?  The catalogue recognises it, but when I try to drag it into my main window ArcMap crashes, no error, just closes.
Am I doing something wrong?
JohnGrammer1425
When you mention VMap are you talking about VPF Data? And is it that you want to visualize the vpf data in ArcMap? You should be able to use the add data button and navigate to the VPF feature class and add it as a layer.
George_Thompson
Esri Frequent Contributor
Can you provide more information about the VMap item?
Is it related to this: VPF To Geodatabase—Help | Documentation (arcgis.com)
Also, 10.2.x is retired and support for it may be very light.
--- George T.
JohnGrammer1425
BenLeslie1
OK, thanks, seems to work if I use the Add data button.  I usually just drag stuff in from the catalogue or Windows explorer.👍
