Import xml workspace in ArcGIS Pro fails
119
07-19-2022 09:49 AM
EdithKonopka
The xml workspace was exported from a production enterprise geodatabase on Oracle, as schema only. The source contains a feature dataset with a topology, feature classes, tables, and relationship classes. The source also contains other tables and feature classes, and relationship classes. The total number of geodatabase objects is about 30. The geodatabase is at 10.7.1, Oracle 12.
We are trying to import the xml workspace into a development Oracle geodatabase at 10.7.1, Oracle 19. It appears to be failing because there is no way to specify the separate keyword required for the topology. I experienced the same problem when using this tool in ArcCatalog between enterprise geodatabases at identical releases and Oracle 12 on both.
Is there a workaround to run this tool successfully?
EdithKonopka
Got it working by specifying the topology keyword instead of the keyword for all the other data.
EdithKonopka
