How to perform an analysis with these criteria
292
08-15-2022 05:28 AM
NoayavRee
New Contributor II
Hello,
I'm quite new to ArcGis and everything that comes along with it and struggle with an assignment that I have. It is about finding suitable excavation points for which I have gotten several different types of maps to combine and analyse. For most of the requirements I have found the solution already, however, I'm not really sure what type of data handling/operation to use to find the solution to the following criteria:
- Excavation points are not allowed in areas of forest with a minimum of 10ha adjacent to a specific habitat. A shape file is provided to analyse this.
I thought this should be handled by processing by neighbourhood and buffering, but I'm not sure
- Another criteria is that the thickness of sandlayer needs to be at least 5m. I have been given sampling sites and a table with the findings belonging to these sites
The only thing I could think of was processing by attribute and then joins and relates, but that also seems like the wrong thing to do.
Perhaps there is anyone that can give me a tip or hint? Or maybe some place where I can find more info on these types of analysis?
Kind Regards
JohannesLindner
MVP Frequent Contributor
It's hard to give specific tips without knowing your data, but here are some general ones:
Sand layer thickness
  • Join the sampling results to the sites. The goal here is to have a point layer with a sand thickness attribute.
  • Now convert this point layer into a polygon layer of areas with thickness >= 5m
    • Either Create Thiessen Polygons, then select and delete all polygons where thickness < 5m
    • or interpolate a raster of sand thickness with (for example) IDW, use the Raster Calculator to create a raster where all cells with sand thickness >= 5m get the same value and all other cells are null, then convert the Raster to Polygon
  • These polygons are suitable according to the requirement.
Neighboring a specific habitat
  • Create a layer of forests with an area > 10 hectares
  • Select the habitat(s)
  • Select Layer By Location, using the habitat layer as selecting features and a relationship of "Intersects", "Within Distance", or "Boundary Touches", depending on your data. Check "Invert Spatial Relationship".
  • The selected forest polygons are suitable according to the requirement.
Have a great day!
Johannes
NoayavRee
New Contributor II
Thank you so much!
