How to combine fields from attribute table?
678
08-30-2022 08:32 AM
NoayavRee
New Contributor II
Hello,
I'm currently working on a ArcGIS task, however I'm struggling with an analysis that I want to do. It concerns the following;
I need to perform an analysis on the thickness of specific sandlayers. I have two files for this; one is a point file with specific boreholes and the other one is a table. I have already combined the two, but I need to figure out in what boreholes the sand thickness is at least 3,5m. However, I only know the height of the bottom and the top of the layer of sand. This means that I need to find a way to somehow select those boreholes in which height between the top layer and bottom layers is >3,5m. I was thinking that I have to some processing by substracting the height of the bottom from the height of the top to see the thickness of the boreholes. However, I can't seem to find the right solution to do this and find out what points are suitable or not.
Anyone can give me any tips or advise?
Thank you in advance!
JohannesLindner
MVP Frequent Contributor
  • start the "Select Layer By Attribute" tool
  • set the input rows to your layer, selection type to "new selection"
  • create a new SQL expression
  • BOTTOMSAND - TOPSAND >= 3.5
  • Apply
Have a great day!
Johannes
EiLaza
nvm
NoayavRee
New Contributor II
Thank you!
However, I'm not sure what SQL statement should be given. I tried something, but it seems to be wrong. I don't know whether that is cause I have an older version of the program.
JohannesLindner
Try it without the quotes. Just
layerdikte.BOTTOMSAND - layerdikte.TOPSAND >= 3.5
Have a great day!
Johannes
