Extracting GPS information from data collected on Field Maps/Survey123
205
03-10-2023 03:57 PM
GISJess
I was curious if there was a way to extract GPS info for records within a layer. It would be nice to see whether the data was taken using integrated or external GPS, and what the overall GPS accuracy is.
Is there a way to pull this info from records? A tool or script that exists?
Thanks.
ChristopherCounsell
MVP Regular Contributor
You may need to enable it first:
https://doc.arcgis.com/en/field-maps/android/help/high-accuracy-data-collection.htm#ESRI_SECTION1_C9...
Then they should appear as fields in the layer.
