Error: ERROR 000520: Unexpected TopoEngine Error ----- Exporting Feature Classes to CAD
254
11-21-2023 12:30 PM
Labels (3)
AvaPatterson
New Contributor III
I'm trying to export feature classes (tested shapefile too) to DGN and I keep receiving this error. I've tried exporting a smaller subset of features, moving them to a different database, and exporting as DWG. I've also tried checking and repairing geometry (there weren't any).
DanPatterson
MVP Esteemed Contributor
Did you create a featureclass in a locally stored file geodatabase as the source file?  It sometimes corrects geometry and/or topology issues.
... sort of retired...
AvaPatterson
New Contributor III
Yes all the data is local.
MarceloMarques
Esri Technical Support - Error: 000520 : Unexpected TopoEngine Error (esri.com)
 000520: Unexpected TopoEngine Error.—ArcGIS Pro | Documentation
if still encounter issues then open a ticket with Esri Technical Support to investigate.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
