Create a Branch Version
670
7
06-02-2022 03:18 AM
Abdullah_AlFazari
Team,
I'm trying to create a new branch version from our traditional DB.
What I can find in the Geodatabase Connection Properties is the below:
I've read about this and I came to know that it should be similar to the below where I can select Branch:
I'm connecting to GDB using the admin user
Any thoughts please?
George_Thompson
Esri Frequent Contributor
There are a couple of items here:
First - You need to branch version the data that you want to use; https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/register-a-dataset-as-branc...
Second - Publish the data to ArcGIS Enterprise and use the feature services (that you just  published) in ArcGIS Pro (or webmap / app) to edit
Note - you can not have the same datasets (feature classes) both Branch and Traditional versioned. It is one or the other.
Here is some information on branch versioning: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/branch-version-scenarios.ht...
--- George T.
Abdullah_AlFazari
Hi @George_Thompson
Thank you very much for your response. Much appreciated. Let me check all of this and hopefully, it'll work.
Abdullah_AlFazari
HI @George_Thompson
I went through what you have mentioned and found the below error while I'm trying to enable the branch versioniong of the data:
Any thoughts?
George_Thompson
What type of data are you trying to branch version?
  • Feature Dataset?
  • Feature class(es)?
  • Table?
  • View?
--- George T.
Abdullah_AlFazari
Hello @George_Thompson
I'm trying with a Feature Dataset.
George_Thompson
What type of data is in the Feature Dataset?
  • Geometric Networks / Topology / etc?
--- George T.
Abdullah_AlFazari
This Feature Dataset has only one Feature Class which is containing points. I also created global IDs for those points.
