Points are not showing in map when data is versioned
478
04-19-2022 08:32 AM
FiorellaRodriguez
Hello,
I have an issue with versioning. This happened after we upgraded AGE from 10.8.1 to 10.9.1
Enviroment:
AGE 10.9.1 federated
ArcGIS Pro 2.9.2
EGDB Branch versioned
This is only happening with 2 features classes in different datasets. All other features versioned are working fine.
Problem:
The feature layer is not showing points, it cannot draw them in the map, however in the attribute table it does show all elements (around 12000). As soon as we unregistered as versioned all point show in the map, and then disappeared when we registered as versioned. We repaired geometry and tried again with the same behavior.
Does anyone have any suggestions?
Thank you
BillFox
MVP Frequent Contributor
Is copying all the features into a new layer (temp...X) an option for you?
Then delete the bad one and copy the temp one as the same name.
Then register as versioned.
