Preserve indents when pasting code as preformatted text
659
04-01-2022 06:43 AM
Status: Closed
Bud
Notable Contributor
There are times when we want to use preformatted text instead of code blocks:
  • We can format preformatted text, unlike with code blocks.
  • Code blocks are clunky to use (extra line breaks, awkward clicks when trying to edit).
With that said, there is an issue with preformatted text. When I copy code from an IDE (such as SQL Developer), the indents get stripped out:
--https://community.esri.com/t5/arcgis-enterprise-questions/pl-sql-code-review-set-polyline-m-values-to/td-p/1159398
with
function pythagoras(x1 in number, y1 in number, x2 in number, y2 in number) return number is
begin
return round(sqrt( (x2 - x1) * (x2 - x1) + (y2 - y1) * (y2 - y1)), 2); -- Power is a slow function
end;
function m_as_length(shape in sde.st_geometry) return varchar2
is
result varchar2(32767);
vertex_set varchar2(32767);
oldX number;
oldY number;
newX number;
newY number;
line_len number := 0;
begin
for vPartIndex in 1..sde.st_geometry_operators.st_numgeometries_f(shape)
loop
vertex_set := null;
for vPointIndex in 1..sde.st_geometry_operators.st_numpoints_f(sde.st_geometry_operators.ST_GeometryN_f(shape,vPartIndex))
loop
newX := sde.st_geometry_operators.st_x_f(sde.st_geometry_operators.st_pointn_f(sde.st_geometry_operators.st_geometryn_f(shape,vPartIndex),vPointIndex));
newY := sde.st_geometry_operators.st_y_f(sde.st_geometry_operators.st_pointn_f(sde.st_geometry_operators.st_geometryn_f(shape,vPartIndex),vPointIndex));
if vPointIndex <> 1 then
line_len := line_len + pythagoras(oldX, oldY, newX, newY);
end if;
oldX := newX;
oldY := newY;
vertex_set := vertex_set || newX || ' ' || newY || ' ' || line_len || ', ';
end loop;
result := result || '(' || rtrim((vertex_set),', ') || '),';
end loop;
return 'MULTILINESTRING M (' || rtrim((result),',') || ')';
end;
select
m_as_length(shape)
from
polyline
(That happens, even though the indents are literal spaces in SQL Developer, not tabs.)
That's not what we want. For example, if I were to copy my code elsewhere (such as Stack Overflow), and then paste it from S.O. as preformatted text, then the indents will be preserved:
with
    begin
    end;
    is
        oldX                number;
        oldY                number;
        newX                number;
        newY                number;
    begin
        loop
            vertex_set      := null;
            loop
                end if;
                oldX        := newX;
                oldY        := newY;
            end loop;
        end loop;
    end;
select
    m_as_length(shape)
from
    polyline
So, we can see that the preformatted text is capable of handling pasted indents, in some cases.
Idea:
Could preformatted text be enhanced so that pasted indents are always preserved?
(even when pasting from IDEs like SQL Developer)
1 Comment
SimiBasu
Status changed to: Closed
Thank you @Bud for this idea. We are limited to the functionality of the text editor our vendor is using. They plan to upgrade this editor (TinyMCE) next year, which might offer additional options, but for now this is not something we can change. Thanks Simi.
