Programmatically restore a calcite panel that was dismissed
384
05-02-2022 02:17 PM
LefterisKoumis
Occasional Contributor III
I am using a panel that would like  programmatically reverse the status set by using the dismissible and dismissed properties.
If use the dismissible property and the x is clicked, wanted to programmatically restore the panel visibility.
<calcite-panel dismissible id="X">
          <div slot="header-content">Test</div>
Tried:
document.getElementById("X").style.display = 'block'
Also, if the panel is originally hidden
<calcite-panel dismissed id="X">
Tried
and
 document.getElementsByTagName("calcite-panel").dismissed = false
BenElan
BenElan
Using the dismissed property is the correct approach. Here is a codepen:
https://codepen.io/benesri/pen/wvyBgZV?editors=1000
