Calcite Design System Questions
76
443.1K
167
Open | Could you add a header slot to the popover and other calcite components that are similar? Currently I use a calcite l... by René_Ténière Occasional Contributor 0 0 | 0 | 0 | |
Open | More detailed documents will help developers to use the components. The document is not detailed enough.For the shel... by baohuachu2 New Contributor II 0 0 | 0 | 0 | |
Under Consideration | Both the DatePicker and InputDatePicker have a range option.The TimePickers should have a range option also. Or add a... by RobertMEIER Occasional Contributor 0 1 | 0 | 1 | |
Implemented | When using calcite-input, the type is reflected on the input component, but on in the HTML. So when I use the input ... by TomSellsted MVP Regular Contributor 0 2 | 0 | 2 | |
In Product Plan | The menu components may contains grouped folded sub menu items which long menu bar can be avoided. Furthermore it i... by baohuachu2 New Contributor II 0 4 | 0 | 4 |
Idea Submission Guidelines
