Attribute Rules in FBGD shared to ArcGIS Online Dont Run
532
11-30-2022 10:10 AM
JeraldAllen
New Contributor III
Hello all, I have created a geodatabase for storm structures/pipes and want to have the pipes automatically calc some fields based on the points they are connected to. I have successfully written the attribute rules to do this and they work fine in arcgis pro. However, when I share them to arcgis as a feature layer and draw a pipe in the map viewer, the popup does not show the id calculated.  I started to go down the road of pop-up configuration/attribute expressions, but isnt that what the AR is for? Also, the arcade expression in the AR doesnt work in the Attribute Expressions so i figured I am going about this all wrong. Help?
MikeMillerGIS
Esri Frequent Contributor
You can, but you need ArcGIS Enterprise and an enterprise database.
MikeMillerGIS
ArcGIS Online hosted feature layers do not support attribute rules.  Your attribute rule is being stripped during publishing.
JeraldAllen
New Contributor III
Dang, That's not what I wanted to hear! lol This article says differently (i think) but sounds like you have experience and know that its not the case.  This would be a game changer for our workflows if this would actually work.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/share-datasets-with-attribu...
MikeMillerGIS
JeraldAllen
New Contributor III
Ah, that makes sense.. Thanks for the response!
