What should I change to run this python script on the specific layers only (not all the layers in the MXD) , or just some layers in a group ?
840
09-17-2023 11:59 AM
Labels (3)
MAMDOUHZALAKY
New Contributor III
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
for lyr in arcpy.mapping.ListLayers(mxd):
     if lyr.supports("DEFINITIONQUERY"):
         lyr.definitionQuery = "INSERT_YOUR_DQ_HERE"
JohannesLindner
MVP Frequent Contributor
To insert formatted code:
If your definition query is the same for all specified layers:
layer_names = ["Layer A", "Layer B", "Layer E"]
    if lyr.name in layer_names and lyr.supports("DEFINITIONQUERY"):
If you want different queries for the layers:
queries = {
    "Layer A": "Query for Layer A",
    "Layer B": "Query for Layer B",
    "Layer E": "Query for Layer E",
    if lyr.name in queries and lyr.supports("DEFINITIONQUERY"):
        lyr.definitionQuery = queries[lyr.name]
Have a great day!
Johannes
JeffHouser
New Contributor III
For example, maybe try the following:
For file geodatabase (gdb) or shapefile:
lyr.definitionQuery = '"Docket"' + " = " + "'1254-2017'"
or for personal gdb
lyr.definitionQuery = '[Docket]' + " = " + "'1254-2017'"
-Jeff
MAMDOUHZALAKY
New Contributor III
Can you explain to me with more details .... what should i replace in my python script to do what i want ? I do not understand Docket"' + " = " + "'1254-2017'" !!
JeffHouser
New Contributor III
Docket = field in the layers attribute file.
'1254-2017' = is a specific txt value.
Please also refer to JL's post... Great info
-Jeff
JohannesLindner
queries = {
Have a great day!
Johannes
