How could I add Fme tool in arcmap toolbox to check QA
196
09-21-2023 01:43 AM
JokerEsri
Hello ,
Could I add FME in toolbox of arcmap ?
i would like to create new workspace with Fme to check QA before saving the data into database .
so will be possible , to create new tool to check as example lines and overlapped objects if exist and more ….
to check if there is error so we correct it before saving in A D tables then go to our database .
AyanPalit
@JokerEsri Esri and FME have worked together for a long time and the ArcGIS Data Interoperability extension provides  integrated spatial ETL toolset using Safe Software's FME technology.
For data QA/QC you may also use ArcGIS Data Reviewer that provides a comprehensive set of spatial and attribute checks.
Ayan Palit | Principal Consultant Esri
JokerEsri
Thanks for ur reply .
i did not get the idea .how to add FME in tool box for arcmap ?
i have FME and arcmap ,but I did not find at toolbox ArcGIS Data Interoperability extension tool ? What should I do ?
sorry ,I am still beginner with using Fme and arcmap
about license ,I have Fme license and arcmap license .
should my company buy also extra license from Esri for that ?
